Quickjack lifting post for various MBs
Old Apr 22, 2024 | 09:18 PM
SerottaD's Avatar
1993 300SL,2007 RAM 2500,2009 CLK350,2011 ML550,2016 McLaren 650S,2018 AMG E63s wgn,2018 AMG SLC43
I'm looking at QuickJack to move away from the "drive front wheels up a ramp" approach I've used for decades. Get more height than the ramps (enough room to actually use a creeper) and get rid of need to protect with jack stands backing the ramps.
Simple question, do you also have to buy aftermarket pucks to go into the "pockets" under the car or can you use the rectangular blocks Quickjack provides and bridge across the outer edges of the Mercedes pockets (that is, nothing goes into the Mercedes-provided "pocket").
I'm measuring for a 1993 300SL, a 2018 SLC43 and a 2018 E63 S, which all seem to have the standard "pocket".
I bought an aftermarket puck (https://www.ebay.com/itm/364453892055) for emergency use with the round lifting cup on most rolling floor jacks, but round doesn't look like it fits the rectangular pocket on the Quickjack. Also, the tab that fits into the pocket on what I bought is overly tall, so I wonder about stability.
Anyone use Quickjacks? What's your set up? I saw another post but the details of the interface puck/pad wasn't discussed.
Old Apr 23, 2024 | 02:42 AM
streborx's Avatar
Top Answer: 1
G550
Just curious -- what kind of maintenance are you doing that benefits from a full frame lift?
Old Apr 23, 2024 | 08:28 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I just use the rectangular blocks provided with the lift. Ensure you get the blocks inside the side-skirt or you run the risk of cracking/fracturing the plastic. Check twice, lift once.
It is nice to have the car lifted at all four corners for pulling wheels, rotating tires, brake and/or suspension work. I also use the lift to raise the car, place six inch thick wood blocks under each tire, then lower onto the blocks and perform an alignment. Used to be pulling a floor jack around the car to lift a corner at a time was a PITA. Much easier now.
Be aware the Quickjack model I have is marginal for being long enough to reach the lift points so ensure the one you purchase is long enough to reach the jack points. I recommend against the add-on extensions as they change the geometry of the lift and the lift cannot quite get the car off the ground. The hydraulic cylinders should be pressurized with compressed air to ~50 psi to allow the lifts to lower fully. If the pressure is low, the car's weight will compress the lifts but once the tires are on the ground the car's weight is off the lifts and it seems to take forever for the lifts to lower the final few inches.
Would I buy them again? Yes. Would I recommend them? Yes.
Old Apr 23, 2024 | 09:08 AM
streborx's Avatar
Top Answer: 1
G550
My most frequent lifting need is for oil changes, and Rhino Ramps are the best method for me. I have a couple trolley jacks, one with a 2 point lifting arm that can lift 2 wheels at a time, but it's not for under-carriage work. I did need all 4 corners lifted a couple years ago for a transfer case changeout, and I used 2 ramps and 2 8x8 wood blocks on the rear. I have jack stands but am untrusting. I'd probably never use the quickjacks enough to justify finding a place to store them.
Old Apr 23, 2024 | 01:40 PM
SerottaD's Avatar
Make oil changes easier because of more height. All the Mercedes have under engine pans that need removal.
QuickJack website says you can get the ramps wet, so I'd love to jack the car for detailing, which is done much more frequently than on our CLK350 daily driver. Wheels are such a pain and I'd much rather sit on a creeper and rotate the wheels to get really clean. Same for front fascias, which are their own detailing project. Washing under the rockers is also a pain. I'm getting old. Kneeling and getting wet gets old.
I have a specific project on my '93 300SL-24 where I need to rebuild the ADS distribution manifold. Scoping out where all the lines go with the car on ramps is impossible.
My RAM 2500 is not so much an issue as once it's up on ramps, it sits pretty high. Truck has stock-size wheels.
I'm a bit concerned about storage space, but buying the accessory that lets you hang it on the wall seems to solve that problem.
Old Apr 23, 2024 | 02:05 PM
streborx's Avatar
Top Answer: 1
G550
I've never dropped an oil pan to do an oil change on any car. What have I been doing wrong?
Old Apr 23, 2024 | 03:36 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Belly pans. Quickjack makes it so much easier.
I leave the lifts on the garage floor just pushed together so my car's tires straddle the lifts. Those suckers are heavy!
Old Apr 23, 2024 | 05:02 PM
SerottaD's Avatar
Not the oil pan, but the engine compartment under-cover. All our Mercedes have them. Same 8 mm bolts scattered about. A little smaller than a square yard. Remove bolts, have it land on your chest, remove, do maintenance, replace. The CLK has two covers that have to come off, one overlapping the other. Can't get to the drain plug otherwise. Don't need to do this if you have the equipment to suck out the oil from the top, but dunno if that is as thorough (although I don't have the tool).
