Front Right Resonanating Noise
Old Sep 14, 2024 | 10:18 AM
YYC53's Avatar
2020 E53 AMG
I have a '20 E53 that I purchased this spring. The car has reasonably worn PZ4's and soon developed a sort of humming or resonance out of the front right axle. It's difficult to describe, but it comes across as a mechanical hum that resonates in and out at higher speeds. It seems to be worse in dry/higher grip surfaces or with the car at lower ride heights. Seems to come on a bit more in straight lines than in curves but is present at times in corners. Probably has something to do with road camber and flat vs slightly troughed pavement. I've a brand new set of balanced tires and an alignment done but can feel it a tiny amount in the steering. The rim was checked for bend during the tire install at a good tire shop I trust. Mercedes also had a look at that rim.
Oddly, I've had wheel bearings and drive joints go in my other two vehicles on the front right, so I've some recent experience with this. I can only presume pothole prevalence is worse near the curb! You can' dodge tall of them!
My concern is that the noise is so subtle that I am pretty sure the dealer will say, 'nope, nothing wrong there'.
I'm thinking this could be wheel bearing, front diff exit bearing or CV/drive joint.
Has anybody had failure of these? What was the behavior of the noise/feel?
Old May 4, 2025 | 04:16 PM
6speeddave's Avatar
MB
Did you get this resolved by chance? What is a front wheel bearing?
Old May 11, 2025 | 06:00 PM
exturnul's Avatar
2021 CLS 53 AMG C257, 2023 W223 S580, 2021 X167 GLS450, 2022 V167 GLE350
i have this issue too, even after replacing wheels and tires. also always at 80mph+. please keep us updated.
Old May 11, 2025 | 06:37 PM
Cosworth2000's Avatar
2022 E53 AMG
I know there is something wrong with your front wheel bearing or maybe the CV. If the sound does not go away then that is your bearing but if you only hear it when you turn, then its you CV.
Old May 11, 2025 | 08:20 PM
6speeddave's Avatar
MB
I emailed the OP yesterday and he replied that it ended up being a bent OEM wheel.
Old May 11, 2025 | 08:58 PM
exturnul's Avatar
Thanks, will get it looked at during B service.
Old May 11, 2025 | 09:07 PM
2022 E53 AMG
Wow.. a bent rim? I have never heard anything when my rim was bent but more like a feelng.
