Winter tires- 265/40/19 vs 255/40/19
Old Oct 23, 2024 | 05:01 PM
WildWolf's Avatar
2019 E63s
Currently have 265/40/19 on the winter wheels. Tires need to be replaced. What do I give up by going to a 255/40/19 tire (aside from 10mm)? Rims are 9" wide. The 255 is significantly less expensive than the 265. thx in advance
Old Oct 23, 2024 | 05:14 PM
superswiss's Avatar
2019 C63CS
Skinnier is better if you actually drive in the snow as the tires are more likely to dig down to the pavement, so you are actually gaining something. You do lose a little bit of sidewall. Not a lot and it's probably barely worth it, but especially if you drive on snow, not knowing what's underneath, more sidewall is better. Other than that, the diameter is a little less, so your actual speed will be a little less for any given speed shown on the speedometer.
