OEM wheel options for E53
Old Feb 10, 2025 | 08:20 PM
C300Brett's Avatar
1987 560SL | 2022 E53 AMG
Hi everyone,
Looking for some help here. Just picked up a 2022 E53 and love the car, but am not crazy about the 19" OEM wheels with the "inner circle" design that came standard. I really like the 20" Multi-spokes" that were optional, but am having a problem finding a set for a reasonable price (and with that same visual style used on so many other models, it's hard to know if what I'm looking at being sold is actually an E53 wheel). I did get the part numbers for them from the MB site so that's a way I could confirm.
The specs I found for the E53 Wheels are
  • Bolt 5X112mm
  • Center Bore 66.6mm
  • Offset 49mm
  • Front ET 20
  • Rear ET 43
  • Width 9"
My question is, are there any other MB models that have similar / the same wheel specs - specifically Offset / ET numbers as the bolt pattern looks the same cross the board. I don't feel good about using spacers so would like to avoid that.
I read a post on another forum that seemed to say that a guy found that W222 S63 wheels would fit on an E53, but I just don't know enough to be sure. the specs for those rims are:
  • 8.5 x 20 ET 39
  • 9.5 x 20 ET 39
Is that close enough not to give me problems? Just finding this all pretty confusing.
Thanks for any help / advice!
Old Feb 11, 2025 | 09:52 AM
bobblehead's Avatar
go fast grocery getter wagon
W222 FL has this setup .... AMG
Front: you would be 26mm closer to the suspension strut - you will need at least 22-25mm spacers and longer bolts
Rear: wheel will be 17mm extended out and there is a good chance your tire will touch the wheel well fender, esp. if lowered. Also, you will likely picking up more stones and thrown onto the rear fender as well which can cause scratches to painted surface.
Old Feb 11, 2025 | 03:33 PM
bobblehead's Avatar
the E class amg front wheel offset is very troublesome to find for a good fit. you can go aftermarket but the choices are not many (for front).
If you are going to keep the car for a long time, maybe consider going custom made ?? It can be expensive but you get the exact style and offset (forged will run you about $2-$2.5K a piece at least if made in the US).
Old Mar 7, 2025 | 09:33 PM
asinga01's Avatar
2022 E53
Don't the 2019 E43 5 spoke 19 inch fit?
