Does anyone wash their engine bay?
Old Apr 1, 2025 | 07:16 AM
W205C43PFL's Avatar
Originally Posted by E63S Hopeful
I can only hope it's just a dead battery. With her being parked outside on the daily since we arrived here (and not driven for weeks at a time) I can only imagine how degraded the battery is from constant weather variations. I was not able to charge or jump start the car as I had limited options at the car wash.
I'm the second owner of this 2018 E63S, which I purchased in 2021. Since owning it I have not replaced the battery, and there isn't any documentation from the previous owner that the battery was replaced. So potentially I am still operating on the original battery...(hmmm).
Mike
I see. Sounds like the the other forum member found the issue for you.
Old Apr 1, 2025 | 09:52 AM
zukmeister's Avatar
2023 E63S AMG - Grey Magno
Mike
All your signs point to a dead battery to me. Don't let the shop you took it to talk you into anything else until that battery is checked
Old Apr 1, 2025 | 10:39 AM
E63S Hopeful's Avatar
2014 Jeep Grand Cherokee SRT (sold) 1993 Mazda RX7 (sold)
Really hoping for that. Currently she is at the Mercedes dealer here in Frankfurt, Germany and they have been straight shooters. Fingers crossed.
Mike
Old Apr 1, 2025 | 12:26 PM
W205C43PFL's Avatar
Mike
Sounds good, all indicates a bad battery after all.
Old Apr 1, 2025 | 04:11 PM
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
I use vacuum and compressed air... get rid of junk and debris...
then I use tire foam that cleans and dresses... most of the engines are plastic or carbon fiber covers...
use a mid size and smaller bristle bush to get nooks and crannies and respray foam and use compressed air...
then final wipe down with older MF cloths/rags
Old Apr 1, 2025 | 07:23 PM
W205C43PFL's Avatar
That is one way : )
Old Apr 2, 2025 | 10:08 AM
  #32
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
After a RMS replacement (twice) at an incompetent local dealer I took it to a reliable local. They removed all the covers and did a detailed inspection to be sure the dealer actually fixed the leak. Then it went over to a shop that does steam cleaning and they cleaned the entire bottom & engine area (top & bottom). Then a month later back to the shop for another inspection and the covers to be put back on. No issues with the cleaning and the shop did say it came out really clean.
Old Apr 2, 2025 | 06:49 PM
  #33
FastWgn's Avatar
2016 E63 Wagon
Hmmm, there is a lot of interesting info on this thread.
First things first - you can 100% clean your engine using a hose and a citrus based degreaser. Modern connectors are very well protected against water intrusion.
Never wash a hot engine, note that modern engines get "hot" MUCH faster than cars 15 or 20 years ago.
Never use high pressure sprayer.
It is good safety measure to remove ground from the battery before starting, but not necessary in 99% of cases.
When washing - try to avoid spraying directly at sensitive equipment (in our cars in particular the ECU connectors - the box is fine - it's 100% water proof - but be careful - better to use wipes there)
Don't leave car running while washing! Two reasons. First - certain parts (exhaust, cats etc) will be warm vey fast and if you then spray water on it you do run the risk of the metal cracking. Second - many, many more parts are energized when running and at higher voltages (ignition coils for example).
Once done, if you have compressed air - blow *gently* to remove any obvious puddles etc. Then wipe down with rag or microfiber.
Now, as someone said above - go drive the car. At least 20-30 minutes, and at highway speed. Park, leave hood up for 10-20 minutes for moisture to evaporate. Wipe down again since there will be water spots.
To OP: as weird as it sounds, I think you have another issue, like weak battery.
Old Apr 2, 2025 | 08:12 PM
  #34
superswiss's Avatar
2019 C63CS
At this point further posts are just guessing and at best unproven claims. We won't know what really caused it until he gets word back from the dealership in Frankfurt. Given how long it seems to take for them to diagnose the issue I suspect it's more than just a weak battery.
Old Apr 2, 2025 | 11:06 PM
  #35
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Previous posts have been very informative. There is no reason to believe further posts won’t be at worst, unproven claims.
Old Apr 2, 2025 | 11:28 PM
  #36
PeterUbers's Avatar
We are professional speculators - no one beats Mbworld 'regulars' on speculation ... no one.
(whispered: "no one")
Old Apr 3, 2025 | 02:15 AM
  #37
Got the car back yesterday evening!
To those that said weak/battery issue, you were spot on! Battery failed all tests and diagnostics and was therefore replaced. As the receipt and all documentation is in German, there would be no point in cutting and pasting it here, but I have done my best to translate and provide the details and costs below:
-Perform a short test: 63.61
-Maintain vehicle electrical system voltage (during testing and diagnostic work): 21.30
-Battery system components:..............still check error code: 127.78
-Check the condition of the 12 V vehicle electrical system battery (after a short test): 21.30
-Recharge the battery (after testing): 21.30
-Replace the vehicle electrical system battery (after testing) from 37/17. Doesn't maintain power, always fails.: 85.19
-VEHICLE ELECTRICAL BATTERY: 391.44
-19% Tax: 139.06
-Total: 870.98
A pretty steep and costly mistake on my part, but for sure a lesson learned. I am thankful that I didn't cause any further/major damage because of this.
Much appreciation to the members, and "speculators" :-) who posted here with their thoughts, "good vibes" and alternate engine bay cleaning hacks.
Mike
Old Apr 3, 2025 | 05:26 AM
  #38
W205C43PFL's Avatar
-19% Tax: 139.06
-Total: 870.98
Mike
Glad to hear it was just the battery!
Old Apr 3, 2025 | 07:02 AM
  #39
FastWgn's Avatar
2016 E63 Wagon
OP - Great news!
Keep on washing away and keeping that car clean and nice!
Old Apr 3, 2025 | 09:07 AM
  #40
Originally Posted by FastWgn
OP - Great news!
HA! I will do so, but with an added level of care and attention to detail.
Mike
Old Apr 3, 2025 | 09:25 AM
  #41
W205C43PFL's Avatar
Mike
Remember one thing though, enjoy in good health : )
Old Apr 3, 2025 | 09:48 AM
  #42
zukmeister's Avatar
-19% Tax: 139.06
-Total: 870.98
Mike
Good stuff - I called the bad battery from the very beginning. Glad to hear that's all it was.
Do yourself a favor and get a battery maintainer of sort if you plan to not drive it for weeks and leave it plugged in at the terminals in the front. No need to get a special super fancy one that Mercedes approved or whatever, they all work the same as long as it can handle an AGM battery. I have used them all and NOCO on amazon is a great value for the money.
This is the basic slow trickle one that works great-
Amazon Amazon
This one is much more powerful and will charge quicker if you need it -
Amazon Amazon
Old Apr 3, 2025 | 09:59 AM
  #43
W205C43PFL's Avatar
This is the basic slow trickle one that works great- https://www.amazon.com/NOCO-GENIUS1-...s%2C187&sr=8-1
This one is much more powerful and will charge quicker if you need it - https://www.amazon.com/NOCO-GENIUS10...s%2C187&sr=8-9
Or get the OEM equivalent CTEK : )
Old Apr 3, 2025 | 10:00 AM
  #44
W205C43PFL's Avatar
https://mbworld.org/forums/coupe-roa...ml#post8548131
Old Apr 3, 2025 | 10:28 AM
  #45
I fully plan to pick up a NOCO charger once I return to the U.S.. Unfortunately in order for me to run a trickle charger to the wagon at this apartment complex, I'd have to lay out a 200 yard extension cord from the apartment to the car. I am sure the other residents would not take kindly to this. LOL
Mike
Old Apr 3, 2025 | 10:53 AM
  #46
PeterUbers's Avatar
Congrats! You needed a win and you got one; have a great rest of your week.
Old Apr 3, 2025 | 04:26 PM
  #47
whitewagon's Avatar
Mike
look into a solar trickle charger...i have one on my boat. it works great. don't know if you can get small portable one and mount it on dash...
the one I have for my boat can keep 4 group 31 batteries charged
