P029909 – Turbo Underboost After Stage 1 Tune (E53 AMG)
I’m Octavian owner of the E53_Hulu instagram page, and I’m reaching out to see if anyone has experienced similar issues with their E53 AMG (M256 engine) after a Stage 1 ECU/TCU tune.
Background:
- Car: 2019 Mercedes E53 AMG Saloon
- Tune: Stage 1 ECU & TCU by Pure Tuning (Jan 2025)
- Fault: P029909 – Boost pressure of turbocharger 1 too low (component fault)
- Symptoms: Turbo cuts boost completely, no CEL or warning lights, fault clears with OBD scanner or full ignition cycle
- First occurred in June during hot weather
- Replaced boost pressure sensor behind the turbo – issue resolved
- Returned again recently during another hot spell
- Smoke test done – no leaks from turbo, intake, or vacuum/boost pipes
- Actuator functioning normally
- Car drives fine otherwise, including launches and mixed driving
- Fault only appears in hot ambient conditions
- Booked in with Pure Tuning for diagnostics, but looking for insights in the meantime
- Has anyone else experienced this fault after tuning?
- Could this be related to heat soak, sensor drift, or map calibration?
- Any known fixes or adjustments that resolved it for you?
Thanks in advance!
Background:
Thanks in advance!
