V8 Biturbo 4matic+ label
Old Oct 1, 2025 | 01:13 AM
sixfive's Avatar
'19 E63S
I remember reading something about that but I couldn't figure out what that is called so I thought I'll repeat the question if anybody has figured out a simple way of reattaching the V8 Biturbo 4matic+ label on the front fender as its come quite loose and I'm worried about it falling off . . . took a video but apparently I don't seem to be able to trim it down enough to show it . . .
Old Oct 2, 2025 | 01:40 PM
sixfive's Avatar
'19 E63S
here's a short video of the wing part above the 4-matic label that is loose. When I lift it enough to see behind, which isn't much, I can see some snaps of some sort likely attaching the item to the fender. Are those replaceable?
File Type: mov
Old Oct 2, 2025 | 02:54 PM
zukmeister's Avatar
2023 E63S AMG - Grey Magno
The pins behind those break off quite easily. You'll need to either replace them or add some 3m double sided tape on the back to hold it down.
I recently replaced mine with carbon fiber variant of it and have black ones available if you want them. I'm local to you in Eagle, PM if you want them
