Brake system
Old Apr 8, 2026 | 03:50 PM
Cuore's Avatar
2019 AMG E63s
Brake system
Hi,
taking my E63s on trackday, just wanted to confirm that out cars don't have brake by wire system right?
Asking because in case of brake fade, I should feel pedal getting softer and pedal travel getting longer as a warning size before I lose brakes?
Old Apr 8, 2026 | 05:07 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Nope...your Brembos will be fine, hot and dusty... unless you are an A+ driver more than sufficient, even if you have OE pads. Better if you have EBCs.
Old Apr 8, 2026 | 06:21 PM
wgnlust's Avatar
2021 E63s Loaded Wgn, No CF
From experience, you may want to consider having a new set of tires lined up. My $.02
Old Apr 8, 2026 | 06:31 PM
Originally Posted by wgnlust
My $.02
You mean 2500 cents 😂
Old Apr 9, 2026 | 09:32 AM
streborx's Avatar
Top Answer: 1
G550
If you feel your brakes fading, you need to exit the track immediately. Track officials should be doing brake inspections prior to allowing you to drive. High temp brake fluid is not a bad idea either.
Old Apr 11, 2026 | 05:35 AM
Cuore's Avatar
2019 AMG E63s
Yeah ofc, I think I was even overreacting a bit, as soon as I felt my pedal getting bit softer I would just abort the lap the go for a cooldown lap, thinking its better than losing breaks
Car has some much potential, I was limited by having at max 1 attack lap before brake fade, but I will be doing brake lines + RBF 600 before next track day which should help a lot
Old Apr 11, 2026 | 11:23 AM
streborx's Avatar
Top Answer: 1
G550
If you left-foot brake on the track like many experienced track drivers do, expect your brakes to take a beating -- inspections before and after each track event and frequent fluid changes
Old Apr 13, 2026 | 11:42 AM
figuwx's Avatar
2018 AMG E63s Ed1
there are exactly zero cars with brake by wire.
For safety reason, all cars are either vacuum assist or electric assist with assist being the operative word. If any of the assists fail, there is a hard link between the pedal and the brake piston.
Old Apr 13, 2026 | 11:55 AM
streborx's Avatar
Top Answer: 1
G550
It's worth mentioning that parking brakes have become electric actuated (brake by wire), but this is not the primary braking action as you point out. The ABS assist integrated into the hydraulic system and electric park braking do add confusion to the discussion. For example, which braking system do collision avoidance systems use? Is the electric parking brake deployed if there's a loss of braking action in the hydraulic system? I don't know the answers without researching, and I don't recall seeing any information in the OM.
Old Apr 13, 2026 | 01:10 PM
SerottaD's Avatar
1993 300SL,2007 RAM 2500,2009 CLK350,2011 ML550,2016 McLaren 650S,2018 AMG E63s wgn,2018 AMG SLC43
deleted
Old Apr 13, 2026 | 04:57 PM
figuwx's Avatar
2018 AMG E63s Ed1
It depends.
The Bosch iBooster found in teslas and numerous other cars are electric assist and can infact brake all wheels.
the W213 is a vacuum assist and as such uses the parking brake system to do active braking.
I actually developed an adapter to use the 2nd Gen Tesla model S iBooster on the 87-92 Toyota Supra to facilitate installing a forward facing intake manifold. It works great and with no canbus, it operates as a e-assist brake.
Only reason I know.
