CEL but no usable code
Old Apr 12, 2026 | 01:28 PM
RaleighE63S's Avatar
E63s sedan
Hello all the DIYers out there. My 2018 E63S sedan is idling high and is throwing a CEL but the only related OBD2 code is for high idle. I am thinking vacuum leak, but wonder if any one else has had a high idle issue and what codes it threw? Car has a RennTech tune but was there for 18 months without codes.
thanks for any help!
Raleigh
Old Apr 12, 2026 | 02:23 PM
E63s sedan
Update- the car only idles fast when it is in D or R, idles at 750rpm when in P or N.
Old Apr 12, 2026 | 03:13 PM
streborx's Avatar
Top Answer: 1
G550
What OBD scanner are you using?
Old Apr 12, 2026 | 04:31 PM
E63s sedan
Hello- I use a Autel maxiPRO MP900E.
now I’m thinking it is not a vacuum leak because it is fine if the transmission isn’t in gear. Wondering if a partially clogged transmission filter or passage in the valve body would cause the idle to increase to achieve proper transmission pressure.
Old Apr 13, 2026 | 12:08 PM
streborx's Avatar
Top Answer: 1
G550
Is this RPM issue present in stock and tuned modes?
Old Apr 13, 2026 | 04:15 PM
amg guy's Avatar
2024 GLE 63 S Coupe 2020 E 63 S
Delete
Old Apr 13, 2026 | 06:21 PM
E63s sedan
Yes, I’ve put it back to stock and it does the same thing.
Old Apr 13, 2026 | 06:33 PM
E63s sedan
quick video. Cold start, revs to do self check, settles down. RPMs jump up when I engage D or R.
Old Apr 14, 2026 | 02:22 AM
streborx's Avatar
Top Answer: 1
G550
One further thought -- have you done a transmission calibration reset?
Old Apr 14, 2026 | 05:53 PM
trigital's Avatar
W213 All-terrain
And the winner DTC is...?
Old May 16, 2026 | 10:40 PM
E63s sedan
Solved
Still no code but I did a transmission service and in 25 miles the light is off and car idles perfectly.
hypothesis is that one of the transmission filters was restricted cause the engine to increase rpms at idle to get enough oil through the filter. No evidence but the light is off.
