Carlsson 18 x 9 w/ 35 offset on w209?
Old Mar 6, 2005 | 03:48 AM
freakinfreak's Avatar
2009 BMW 750i, 2008 Toyota Prius
What do I need to do to make a set of Carlsson 18 x 9 (35 offset) wheels fit on a w209?
Old Mar 7, 2005 | 01:51 AM
x15jq's Avatar
Its not gonna be nice, that will hit the strut. What i mean is the inside of the wheel will rub on the strut because of the offset. Addinga spacer will help solve the problem, since you only need about 3-4 mm to make it fit, but then the wheel will be sticking out the fender in the front. The rear will fit no problem but the front will be a problem.
Old Mar 7, 2005 | 01:54 AM
Yeah. I had them mounted and the car wouldn't move. I'm just trying to figure out if it what size spacer I would need and if it would stick out too much.
Old Mar 7, 2005 | 02:41 AM
x15jq's Avatar
You will need I believe a 5mm spacer to clear it but it will look stupid. Plus even if it works, if your suspension compresses, you should expect some dings and deformation of the fender
