Need help with wheel setup. Offset, Bolt Pattern. Confused.
2005 CLK 320
I was doing some research on the net trying to find the cheapest price of the wheels I'm looking at purchasing and practically every site listed them as either 19 x 8.5, 9.5, etc and that was all the information that was given. Now I found a site that not only lists the sizes but the offset and bolt pattern as well and now I don't know which to get. I am planning on the following configuration: 19 x 8.5 235/35/19 for the front and 19 x 9.5 265/30/19. With that said, here's the following information that I've come across and need help by deciding which is the correct configuration for my 2005 CLK 320 so I avoid any rubbing issues or anything else that might interfere with handling, safety, etc. Also, I plan on installing the full Brabus suspension too. Thanks in advance.
Front 19 x 18.5 wheel
1) Bolt Pattern: 4-114.3 Offset:45
2) Bolt Pattern: 5-108 Offset:42
3) Bolt Pattern: 5-112 Offset:32
4) Bolt Pattern: 5-114.3 Offset:20
5) Bolt Pattern: 5-114.3 Offset:32
6) Bolt Pattern: 5-114.3 Offset:35
7) Bolt Pattern: 5-114.3 Offset:45
8) Bolt Pattern: 5-115 Offset:42
9) Bolt Pattern: 5-120 Offset:20
10) Bolt Pattern: 5-120 Offset:35
Rear 19 x 9.5 wheel
1) Bolt Pattern: 5-112 Offset:38
2) Bolt Pattern: 5-114.3 Offset:20
3) Bolt Pattern: 5-114.3 Offset:35
4) Bolt Pattern: 5-114.3 Offset:38
5) Bolt Pattern: 5-120 Offset:20
6) Bolt Pattern: 5-120 Offset:35
Rear 19 x 9.5 wheel
TR Moderator & Tire God
depends on the weather
Rear 19 x 9.5 wheel
Rear 19 x 9.5 wheel
