brake question
Old Jul 1, 2005 | 11:31 PM
TMans's Avatar
brake question
I searched the forum and seems that Porterfield pads are the recommended ones. Are there any ceramic pads I should try? Where is the best place to get them? The dealer told me that when I change the pads, I need new sensors as well. Anyone know anything about this? Lastly, does anyone know a place in So Cal (san fernando valley area) where I can get this done? Dealer refused to do anything that is not OEM. Thanks.
Btw- this is for a CLK500.
Old Jul 18, 2005 | 09:37 AM
wnycec's Avatar
2000 CLK 430
It would be good to buy the sensors and they are very inexpensive - like less than five bucks per sensor... when the brakes pads get low, you want the sensor to let u know so...
I have seen a lot of posts regarding porterfield pads also and I plan on purchasing a set to go in combination with my drilled brembo rotors...
http://www.formymercedes.com/porterfield.asp
This is a website where you could purchase the brake pads from - you could also try ebay - I found my rotors on ebay
Old Jul 18, 2005 | 09:40 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
Akebono makes some very nice ceramic pads for the CLK 500
Old Aug 1, 2005 | 02:37 AM
TMans's Avatar
Thanks for the replies. Has anyone tried Akebono? Does anyone know a good place to install the pads and sensors?
Old Nov 11, 2005 | 10:38 AM
dkim's Avatar
2022 911 c4s cab, 2022 Lambo Urus
TMans, did u change your brake pads? i have the same car and need new brakes....porterfield seems a bit pricy? how long are they supposed to last? I need a cheap fix
