Vibration issue, possible bent rim?
Old Aug 24, 2005 | 11:03 PM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
Story is that I 've had the tires balanced three times in the last month, the alignment has been done and redone and the car drives straight, and I had the dealer check the suspension and they say it's fine. I still have a vibration coming through between 60 and 75 mph. Anything above or below that smooths out. I was doing above or around 90 coming back from Houston and it was glass smooth, but if I slowed down to the aforementioned sweet spot, there it was. The only conclusion I can come to is a bent rim. This car did have a wheel bearing freeze on it when my sister owned it and the entire suspension on the wheel that locked up was replaced. Anyone have any ideas?
Old Aug 25, 2005 | 10:06 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
use this site to find a local shop with a GSP9700 Hunter balancer and have them do a road foce variation test to determine what your problem is .....
