Luke: PSI question
Old Sep 29, 2005 | 04:47 PM
Jayhawk's Avatar
S500/W220/2000
Luke: PSI question
I recently bought eight new tires from TTR and the Eagle F1s, mounted on 18" staggard AMG wheels, came w/ 32 psi all around. I also had the Michelin X-Ice tires mounted on my old 16" wheels, and inflated to 32 psi all around. My S500 recommends 29 psi in front and 32 psi in back, and I see many different suggestions on this forum. What do you recommend for my F1s and X-Ices?
Old Sep 29, 2005 | 04:52 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
I would run the pressure about 4 psi higher in the front on the Eagles for better performance and handling and leave the X-Ice tires at 32 all around for winter use for moderate understeer and predictablity in the winter
Old Sep 29, 2005 | 05:57 PM
Jayhawk's Avatar
S500/W220/2000
4psi higher than what they are now, which would be 36 psi in front, or 4psi higher than Mercedes calls for, which would be 33psi in front?
Old Sep 30, 2005 | 09:33 AM
36 in the front
Old Oct 2, 2005 | 07:13 PM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
Luke is correct, I have run the Goodyear's for 12 months and the fronts need 36 when cold and the rear's 34 to 35 cold. I really like the Goodyear's over the Michellin's much quiter and the tread looks better.
Old Oct 2, 2005 | 10:07 PM
gswc322002's Avatar
what do you recommend for P-Zero Nero
what do you recommend PSI for P Zero Nero M&S 18"?
