Luke: Tire Size Question...
Old Oct 3, 2005 | 03:44 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
Hi Luke,
Sorry if this isn't the normal type of question that you answer, but I'm thinking of getting 18x8.5 and 18x9.5 wheels for my 2005 C230 Sport Sedan... I wanted to do some research and a comparison on what tires to buy for it. What are my available options in terms of the size? I can then look it up on tirerack and then probably compare and then order them from you...
Thanks!
Old Oct 3, 2005 | 05:24 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
225/40-18 front
255/35-18R rear
Old Oct 3, 2005 | 06:27 PM
nlpamg's Avatar
thanks so much Luke!
Old Apr 12, 2006 | 04:53 PM
Big_Daddy_Benz's Avatar
2006 C230 Sport Sedan
Phil, How did that tire size work out for you? I am thining about ordering some rims the same size and offset. Do you have any problems with your rims rubbing on the front?
Old Apr 15, 2006 | 11:18 AM
Will they Fit
I have a 2006 C230 sports sedan and want to buy some rims that are 18x8.5 in the front with a 32 offset and 18x9.5 in the rear with a 35 offset will they fit with out rubbing?
Anyone please respond.
Old Apr 17, 2006 | 09:57 AM
I would recommend that you get 18x8 and 18x9 ... with the offset you mentioned to avoid problems
