slightly wider tires on a 4matic?
Old Oct 29, 2005 | 10:36 AM
slk55lvr's Avatar
Luke,
I just purchased a pair of 245/40/17's for a member. My car has 235/45/17's on it now, and if I put these tires on it will have the 235's on the front and the 245's on the back. I've read that you can't use a staggered tire setup on the 4matic as it will harm the suspension. Is a tire difference this small going to be a problem?
Old Oct 29, 2005 | 01:34 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
there may be a chance of problems. The computer in the 4-matic MB cars is going to assume that all 4 corners are exactly the same. You may get some drifting issues or other computer errors pop up... or maybe hopefully nothing will happen. If you want to try running the 245's, I'd run them on all 4 corners.
Old Oct 29, 2005 | 01:39 PM
Chi500's Avatar
Mercedes
Also, the different profiles, 40 vs. 45, might cause some issues.
Old Oct 29, 2005 | 05:05 PM
slk55lvr's Avatar
I was afraid of that Hey thanks for the advice
Old Oct 29, 2005 | 06:19 PM
slk55lvr's Avatar
Hey Luke what do you think? They are pretty close to the same size ( only one depth wider), am I safe running these things with 25's in the front?
Old Nov 5, 2005 | 01:57 AM
slk55lvr's Avatar
luke....will these be ok?
Old Nov 28, 2005 | 06:56 PM
slk55lvr's Avatar
Thanks for helping me out Luke..I'll remember the next time I need tires
