2000 ml320 wheel offset
Old Nov 8, 2005 | 09:53 AM
S4MULA's Avatar
2003 M3
I want to put on a set of OEM 2006 ML wheels that have a 40 mm offset. Trying to detemine if I can use them on my ML....any help would be appreciated. Thanks.
Old Nov 8, 2005 | 12:55 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
Are you sure that the `06 W164 OEM wheels are ET40? Usually the fitment on the W164 is much higher... closer to ET60... If they came off of an `05 W163 then they should bolt right up.
Old Nov 8, 2005 | 03:00 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
the OE ML55 wheel in 2000 had a 52mm offset and the 2006 ML500 OE wheel has a 60mm offset so, I would have to question if the OE wheel has a 40mm offset
