Offset???
C240
Offset???
What offset should I run on the rear with a 19x9.5. I see most of them are between 35mm and 38mm I would like to have a nice sized lip but I dont want to be rubbing on the fender all the time. The car is a 2002 C240.
The offset range you want to stay within while running a 265/30/19 tire on the rear of your C Class is 35-38mm. Anything lower than a 35mm will cause you to have issues catching the inside lip of the rear fender and anything higher than a 38mm will cause you to have issues rubbing the inside body of the vehicle.
