michelin PS2 rotation direction
thanks for the help
Alternately, there are directional tires, that are mounted to rotate in a specific direction.
There are some tires that are both.
My policy has always been to rotate using allowable patterns, at each oil change.
There are two tire issues I find with my vehicle. One is the rears wear out very, very fast. It would be better to permit a front / rear rotation to even out the wear. With my snows I got all the same size and it works.
The other is tire damage. The roads suck and I've lost too many tires and a wheel to this problem.
so if i have a staggered setup, can i rotate from left to right and right to left? or is that not good for these tires?
you can rotate from side to side but, unless you are a nascar driver only turning left, I see no real advantage of doing that
