flat with 20" rims
Old Feb 2, 2006 | 09:12 AM
TectiteE's Avatar
MGT, 12 CLS63 Launch
flat with 20" rims
i ran over a friggen pothole last night and bent both rims on the driver side and both went flat... i had my stock 18" rims put on to replace them... are there any down sides driving with 18" on one side and 20" on the other?
Old Feb 2, 2006 | 10:32 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
depending on what size tires are on your 20's there could be major issues with the traction/yaw control and ABS
Old Feb 2, 2006 | 10:40 AM
TectiteE's Avatar
but its only going to be for acouple of hours while the wheels are being repaired... as long as i be careful, should i be ok? btw fronts are 20x9 and rears 20x10's
Old Feb 2, 2006 | 10:43 AM
deuce zer0's Avatar
E63
you should be fine for a short amount of time.
what kind of rims do you have? you must have hit a rediclous hole...or you may have soft rims.
Old Feb 2, 2006 | 10:58 AM
TectiteE's Avatar
collectizone dd1's, good quality wheels from what i know about them, pretty pricey too so they better be decent
