Will Audi A6 wheels fit W203?
Old Feb 3, 2006 | 10:54 AM
StevenH's Avatar
They are 5x112, 7.5X17 with 35 offset? 235-45-17 tires, any rubbing problems?
Old Feb 3, 2006 | 01:29 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
no ... Audi center bore is smaller than a Benz's center bore
Old Feb 3, 2006 | 02:38 PM
StevenH's Avatar
wheel center bore
What is the diameter of the w203 vs. A6?? Thanks
Old Feb 3, 2006 | 03:36 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
W203 should use 225/45R17 not 235/45R17.
Issues you will have:
#1 Audi A6 wheels have a centerbore of 57.1mm. The hub on your W203 is 66.5mm so you will need to have the centerbores drilled open so that the wheels will fit over your hubs.
#2 The Audi wheels are made to accomodate 14x1.5 factory Audi lugs. These lugs will not work on your W203 which uses 12x1.5 lugs.
Old Feb 3, 2006 | 10:08 PM
Ben'z's Avatar
E320
Good information!
Thanks, Luke and Ken!
