Air Suspension Lowering of S500
Has anyone done this before? I heard all they do is hook it up to the computer and lower your stock airsuspension and BAM!! lowered. Is there a device i can purchase to lower my vehicle myself?
Or How much does it cost to lower your vehicle?
I lowered my car using shorter suspension control arms. They are a little 5 inch bracket that assist in adjusting the ride height of the vehicle. You just remove the stock ones with two bolts and bolt the new one right in. The correct aftermarket arms are adjustable so you can go down even lower if you would like. This is a great way to lower any S Class with air suspension and much less expensive than reprogramming the CPU.
By the way, where are you located????
