Brabus wheels and KW coils
The Wheel Supply offered me a deal on a set of used Brabus Monoblock III 2 pcs wheels 20x9.5 all the way around with Nitto 555 (50% tread left) for around $3K. Wanted to get some input on if this is a good deal.
Also, they offered me a set of KW V2 coils for $1750 plus $225 for labor. I'm interested but the price for both the wheels and coils sound a lil harsh.
Any input is appreciated.
Also, being that those wheels have some age to them (been out of the market place for quite a few years now), the chances that they have been reconditioned and taken apart a time or two is not out of the question.
Just some personal insight.
You are basically looking at around 15-20 lbs of unsprung weight per corner. There 20 inches weight around 35lb each with tires will weight any where from 5-10 lbs per corner. So assuming you currently have 16's on, just the weight of the 20 inches will weight as much as your tire/rim per corner.
Scary, because when I had 18's Carlsson installed on my A6 2.7 my 0-60 slowed by .6sec and I can feel a difference in ride and handling as well, not to mentioni MPG degrade on 1.5mpg on average.
So you do have to weigh what is more import to you. Good luck.
After so many attempt with finding best look vs all other compromises, my current set up is lightweight BBS forged 19 staggered with Carlsson Coilover set as softest setting and ride height with tires that barely clear the fender and never under it.
