Tire bulge
Old Jun 21, 2006 | 01:04 AM
CalMBDriver's Avatar
C32 AMG,
Front Tire bulge - Safe to drive on?
I have noticed a small bulge on the wall of one of my front tires.
I'm just wondering how serious this is?
Do I need to get new tires immediately or am I ok to keep driving on them?
They are on a stock C32 and are probably about 2 to 3 years old. Still have some tread left though.
Thanks.
Old Jun 23, 2006 | 08:29 AM
NZO Wheels's Avatar
This is a bubble and is caused by a tear on the inside of the tire. It is most likely caused by an impact of some sort. The tear alows air pressure to get between the layers of the tire. It will eventually rupture and could do so at speed. Recommend you get the tire changed asap.
Mike
Old Jun 29, 2006 | 10:22 AM
eLTURCOamg's Avatar
Merce-rati
what i dont get is how did your tires last 3 years on a c32
Old Mar 30, 2007 | 02:57 AM
georgedaman's Avatar
GL350
Mike
It is caused by the steel belt support busted between the layers of rubber.If the bulge is lesser then a quarter you can still cruise around with it.
Old Mar 30, 2007 | 09:14 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
that is absolutely incorrect ...
the bubble the original poster referred to is caused by damage to the inner liner of the tire which is allowing air to escape which is then caught by the outer sidewall rubber. In short the tire WILL fail ... there is no way to know
when but it will ... it's just a matter of time and
Old Apr 8, 2007 | 08:02 PM
rbc's Avatar
rbc
'07 S550, '02 S500
Re: Front Tire bulge - Safe to drive on?
BTW, if this ever happens to you while you are in your tire warranty, you may be able to get the tire replaced for free.
Shortly after I got my S550, I noticed a small 2" diameter bulge in my front left tire. My dealer told me that the tires are not covered by MB's warranty, but I should check with Continental (I have the standard 18" Continental tire), because tire manufacturers have their own warranty.
Continental told me on the phone that a bulge is usually caused by potholes, but I should bring in the car to one of their service centers for inspection. After inspection, it was determined to be a tire defect (leak in inner lining), and the tire was replaced for free. That was good because the dealer had wanted $209 plus labor for a new tire.
Old Apr 16, 2007 | 06:08 PM
dorikin_86's Avatar
2005 Renntech C class
Highly recommend that you change it out too.
Typically tire companies won't cover you hitting a pot hole...but it could be something else and you'll get some money back.
