offset for '03 w211 e55
tia!
9.0x19 ET31 (245/35R19) Front
10x19 ET31 (275/30R19) Rear
This will get you flush with the fenders. If you oversize the tires by running 265/35 & 295/30 most likely you will rub all over the place, especially while turning. The tires in the pics below are Michelin Pilot Sport PS2.
will the et31 offset still work with this wide of a tire? i'm getting mixed info from dealers and want to know from someone that has run the wider tires.
