Luke - Long Tread Life Tire Recommendation
Old Oct 10, 2006 | 11:54 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Luke,
My Pirelli PZero Nero M&S are almost worn down to the wear bars in the rear (3/32" remaining) after 10,500 miles of mostly freeway miles. The wear pattern is even across both rear tires. No burnouts or anything...couldn't smoke em even if I wanted since I have too much grip with AWD. The fronts are about halfway worn.
Since tire diameter & tread depth are supposed to match with AWD, I'll need to replace all 4 tires soon.
Do you have a recommendation for a longer lasting tire than the PZero Nero M&S? In order, my priorities are (1) ride/noise comfort, (2) tread life, and (3) performance. Snow traction does not matter. The tire size is 235/45/17.
I specifically am considering the following tires. It's hard for me to compare survey data since a they're not all in the same category. Which of these do you think best fits my needs or is there a better match not on this list?
1. Michelin Pilot Exalto A/S
2. Continental ContiProContact
3. Yokohama AVID H4S
4. Bridgestone Potenza G009
5. Bridgestone Turanza LS-Z ($$$! worth it?)
Old Oct 11, 2006 | 03:07 PM
Jayhawk's Avatar
S500/W220/2000
You might add Goodyear Eagle F1s to the list...
Old Oct 19, 2006 | 10:15 AM
lexrex's Avatar
Jayhawk, thanks for the suggestion about the F1 GS-D3.
Any thoughts Luke?
Old Oct 19, 2006 | 05:20 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
Although I really like the Eagle Jayhawk mentioned the Turanza is the best off of your list and will last longer than the others in most conditions
