I Need a winter package for my car
and have a question about the rims listed below:
4 ASA ST4 Silver w/Machined Lip:
Size Selected: 17x8
Recommended Tire Size: 225/45-17
Wheel Offset: 35mm
1) Will they fit my stock 2007 C230 SS without a problem and will they clear my front brakes?
2) Which tires do you recommend? I do drive in the snow Toronto Canada
3) What is the life expectancy of the Blizzak HR Lm25?
4) Do you recommend anybody in Toronto for mounting them?
5) What can I expect to pay for Custom brokerage and duties? Just an approximative estimate woud be great!
6) From the order date, what should I expect to wait to get them in TO.
Thanks in advance for your help!
Size Selected: 17x8
Wheel Offset: 35mm
TR Moderator & Tire God
Size Selected: 17x8
Wheel Offset: 35mm
1) Will they fit my stock 2007 C230 SS without a problem and will they clear my front brakes? yes
2) Which tires do you recommend? I do drive in the snow Toronto Canada Blizzak LM25
3) What is the life expectancy of the Blizzak HR Lm25? 3-4 seasons typically
4) Do you recommend anybody in Toronto for mounting them?when you get a wheel and tire package they are mounted and balanced so, all you need to do is bolt them on which you can easily do yourself
5) What can I expect to pay for Custom brokerage and duties? Just an approximative estimate woud be great!contact your local UPS hub and they can answer that question
6) From the order date, what should I expect to wait to get them in TO.7-10 days is normal for instock items
answers in redOriginally Posted by reaumur
I Need a winter package for my carand have a question about the rims listed below:
Size Selected: 17x8
Wheel Offset: 35mm
Currently Active Users (1)
