Upper/Lower Control Arm Bushing & Rattle Question
When I tapped the control arm which is mounted higher on the wheel hub assembly I hear a rattle, when I goto the same one on the passenger side, no rattle, sounds solid so I think the problem lies here.
My question is this, is the control arm which is mounted higher on the wheel hub assmebly considered the "upper" control arm, and the one mounted lower the "lower" control arm? If not how exactly do you tell the difference between the "upper" and "lower" control arms?
I just want to make sure before I go and order the parts. Should I replace all the bushings (lower and upper) while I'm at it?
Thanks in Advance,
Rich...
