Luke..HELP
Old Nov 12, 2006 | 02:08 PM
alden168's Avatar
E430 , E500
Luke..HELP
I got 2000 E430 with 19 inch staggered I-forged aero. Offset is 35mm on these package using no hub or spacer. I am planning to get a 2003 E500. Would this set fit on the E500. Bolt pattern is the same but some difference on the offset. The E430 is 35mm and the E500 varies. Your input is highly appreciated.
Old Nov 13, 2006 | 09:10 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
they should work fine with the correct lug hardware as most aftermarket wheels use conical seat lug hardware
