HELPPPPPP Quick question on brakesssssss pleaseeee helpp
Old Dec 2, 2006 | 11:48 AM
PsiTERROR's Avatar
2003 c230k sport 4 door
I need some quick help~I am changing the brake pads and rotors on my 2003 c230k 4doors sports.
How do I press back in the piston?????
I'm using a c-clamp but it won't go in.??? I need some quick help I need it done before1 pm.Thanks
Old Dec 2, 2006 | 11:52 AM
Brian WH's Avatar
CLS 320 CDI 2006
Take off cap to brake reservoir and keep an eye on the level.
Lever back brake pad with screwdriver and, both sides carefully. Then remove.
Old Dec 2, 2006 | 11:54 AM
PsiTERROR's Avatar
huh>>???I'm trying to put in some new pads but it won't fit over the rotor unless I poush back in the piston.So how do I push back in the piston?
Old Dec 2, 2006 | 11:59 AM
Brian WH's Avatar
CLS 320 CDI 2006
If the old pads have been removed, replace them and carefully lever back pistons using the old pads. Remove old pads to check clearance is enough for new pads. OK.
Old Dec 2, 2006 | 12:12 PM
PsiTERROR's Avatar
I'm trying to push it in but it wont go in at all.It stuck.ANY IDEAS?
