W203 wheel size questions
Okay, from what i gather from the other posts
W203 has
center bore: 66.5mm
offset: 31et
bolt pattern: 5x112
(Please correct me if I'm wrong)
What other wheels from other chasis' fit on W203?
W202?
also what is the smallest size that will fit on a C230? 15"?
W203 has
center bore: 66.5mm
offset: 31et
bolt pattern: 5x112
W202?
If you don't have the sport brakes, I'm pretty sure 15" wheels will fit, but 16" for sure.
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Why 15"?
Go to www.tirerack.com for various widths and offset. Offset is dependent on rim width because the AMG Monoblock II fits at 18x8.0 et31 front/rear and 18x9.0 et35 rear.
