Can I get wheels with these specs to fit on my W210?
Wheels:
FRONT: 18" x 8.5" ET44
REAR: 18" x 9.5" ET46
Car:
Basic E320 W210 (no 4Matic or auto-level suspension)
I understand about offsets and I know these offsets and widths are quite a bit different from what is recommended for W210.
With that in mind, I'd like to know:
A) Is it possible to get these wheels to work using H&R spacers?
B) If so, what width spacer?
C) What are the pros/cons of such? (wheels poking out of fenders, etc...)
I'm not worried about bolts or tire sizes yet (one step at a time). Luke, I will definitely order from Tire Rack (I always do). I just want to verify that the wheels will fit before I buy them. If it's not possible to fit them, discussing tires and bolts now would be pointless.
Thanks in advance.
C
Car:
Thanks in advance.
C
Hey, guys i have been doing some reaserch about the offset you described above cause i have a w210 and ended up purchasing a set of 4 monoblocks from a 2001 S55 AMG thinking they wuld fit on my car. The back ones fitted fine without rubbing but the were pretty close to the strut and the size is 275/40 18. The front ones i was not able to fit cause the would rub on the suspension side. The front ones are 245/45 18. I was thinking to follow your advise above and go with a set of 10mm spacers and then get a set of 235/45 18 or 235/40 18. Please let me know what will work best to avoid rubbing. Thanks for the advise guys.
