20's for the 500 SEL
Old Sep 27, 2002 | 12:03 PM
Swank500's Avatar
1984 Mercedes 500 SEL
Question 20's for the 500 SEL
I have a 1984 Mercedes 500 SEL that I am considering installing some 20 inch rims on. Are there any cons to doing this?
Old Sep 27, 2002 | 12:27 PM
AndrewEclipse's Avatar
It Varies
Re: 20's for the 500 SEL
Yep.
20 inch rims are $$$. You have to have low profile tires which means if you live in an area with potholes or roads that are not perfectly paved...good luck. Another thing is tire wear, 20 inch tires normally dont last longer than about 20K....so that involves changing them more often which is costly.
But......on the other hand.....they do look good.
Old Sep 27, 2002 | 12:30 PM
pocholin's Avatar
Volvo V90 CC
Swank500, WELCOME ! ! !
20" wheels would look good (pro), just don't come to Houston because our freeways and roads suck ! (con) they will ruin your new wheels. Why don't you put 18s instead and worry a lot less about potholes?
Old Sep 27, 2002 | 12:57 PM
Swank500's Avatar
Thank You!
Thanks for the suggestions.
Old Sep 27, 2002 | 01:49 PM
Harris's Avatar
check out the Classified. I've a set for sale.
