20's on a 2006 clk 350.
If you go staggered you would have to use a 275 25 20. I'm not sure of you want to do that because you will have NOoo sidewall.
I would use a 37 or 38 ish offset especially in the front because if not you might be touching the shock and have to use a 5mm shim.
IMO. this won't look any better than a 19 unless you drop it. But since you want to stay stock on everything, I'd go with the easiest fitment. those tire sizes in a 20 are not the easiest to find either.
hope that helps..
