Lowering an 03 E500 W211 w/airmatic suspension
Old May 29, 2007 | 08:51 PM
ko123an's Avatar
I know my car doesn't have springs so what would be my best option? I don't mind paying for a lowering system, however I have heard you can lower the car by using washers and tricking it to thinking it's higher so it will stay low at all times. Any good suggestions? I'm putting 20's on my ride and would like it where there's no gap.
Old May 30, 2007 | 02:47 PM
raheelq's Avatar
Eric Sandoval ordered and installed the links for his car and it looked pretty easy and is alot cheaper than a module and safer than washers......Ordered mine and should be here in day now... The site I believe is www.adjustableairride.com
Old Jul 11, 2007 | 09:43 PM
noyu's Avatar
17 E43, 18 GLE400
Any updates on the kit?
How would you like it and how hard it is to install?
Old Jul 13, 2007 | 08:19 PM
Abboushi's Avatar
911's and beyond
search it in the w211 section and just type in lowering in the search this forum section and just wait for All the help in the entire World. Good luck i used washers I cut the original bolt and added 6 washers to each side and Loctite dont forget Loctite. Good luck and Dont spend 300-1100.00 when you can spend 5.00 @ home depot support you local hardware store.
Old Aug 22, 2007 | 06:14 PM
Tariq's Avatar
S500 W223 2021
I did lower Mine E500 by DAS System, its perfect and enough and the car looks lowered enough and amazing.....
