18" staggered set up size question.
Old Jun 15, 2007 | 02:21 PM
DoubleA's Avatar
2013 E-350 4matic
Im looking at upgrading my rims to 18" but I need to know what size tires wouold be the best fit and look. I want a staggered set up but not sure how much to go with. I dont want rubbing and I'd rather not get into buying spacers etc. I currently have 17" E430 sport rims from a 2001. I have a 2001 E320. I have already put new springs, shock, bushings, balljoints etc for a better suspension and now its time for the rims. I like wide but not too wide. Also would I need new lugs? Thanks for your help....
Old Jun 26, 2007 | 02:07 AM
Down South's Avatar
Are the new springs that you put lowering springs?
Old Jun 26, 2007 | 10:12 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
DoubleA, go to www.tirerack.com . They recommend these sizes:
235/45/18
265/35/18
Old Jun 26, 2007 | 10:57 AM
DoubleA's Avatar
2013 E-350 4matic
Thanks I did go to tire rack but I wanted to be sure of the size. I have seen posts that stated different sizes recommened by tire rack so I just want to be sure.
The springs are not lowering springs. They are OEM springs installed at the dealer. if I have to lower them once the rims are on what can I do? I didnt make the decision on the new rims until after I installed the springs.
Old Jun 26, 2007 | 07:07 PM
Down South's Avatar
You can either just change out the pads to smaller ones or change the springs too for more lowering.
