Bigger tires on stock 16" W203 wheels?
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
The stock tires are 205/55/16. Without changing the stock wheels, can I put on tires that are slightly wider while maintaining the same outer diameter of the stock tire? I was thinking of something like a 225/50/16. Would that work?
thanks
Jim
thanks
Jim
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
You need to look and see what the wheel width is, I'm not sure off hand, but as long as they are 7 inches or wider, you can run the 225/50's and it will be fine.
C- 230 Kompressor,C2,C7,Black,JL sub,A/D/S/ amps,Alpine hu and changer
If you call the tirerack, they can tell you the size change for wider tires, and what will fit
1998 C Class 230 Kompressor
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
If you have a lokk at the Toyo site, you can cross reference your existing wheels/tyres with other comparables.
The site is:-
http://www.toyo.co.uk/converter/table14a.html
The site is:-
