**urgent** Need Help Quick!!
Old Aug 3, 2007 | 08:34 AM
brett's Avatar
2004 e320
Exclamation **urgent** Need Help Quick!!
I put 20" ECO wheels (same tire size on all four) on my 04 E320 (W211).
Pulling to the right so brought it to MB and they did an alignment and wheel balance. Get it back and it appears nothing changed. I read the order and it says: "can not preform proper maintenance due to hub not aligned with wheel"
So, does this mean my dealer did not install some vital piece with the wheels? the car vibrates and shimmys between 40mph and 60mph only.
wouldnt be an emergency normally!! but i have to drive the car to FL from NYC and MUST leave tomorrow morning!
any advice???
thanks in advance
Old Aug 3, 2007 | 10:23 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
sounds as if your wheels are not hubcentric ... they make centering rings t correct that very problem
Old Dec 19, 2009 | 12:43 PM
BX E320's Avatar
2004 mercedes e320
hey brett i was going to by 04 e320 with 20" rims as well froma dealer. i took it for a test drive and felt the same the way you describing. i think 20"s too big . hope i helped. try smaller rims
