Strut Bolt Clearance on CLK55
Old Aug 14, 2007 | 09:58 AM
AMG_FL's Avatar
'02 CLK55
I just put new tires on the front of my 2002 CLK55. They are the same stated size as the tires coming off (235/35/19), but the actual width of the new Falken's is more than the old Pirelli's. I only have 3mm clearance between the the bottom of the bolt on the strut and the side of the tire - the nut is roughly the same clearance too. I haven't driven it out of the garage yet b/c I am worried it may rub when hitting a bump/taking a turn. Does anyone know if 3mm is enough clearance or if tire deflection/other driving dynamics would make this unsafe?
I am already out to the fender with a spacer to clear Brembo brake kit so I can't just fix it with a biger spacer.
