direction of tires? and wheel cover info
also, the wheel covers that i had gotten has two grooves for the metal ring. i had to shift the ring to the inner groove to make it tighter on the wheel. (by default, they were on the outer groove). be careful when you put them on. i broke off one of the plastic tabs.
just to confirm, the arrow on the snow tires that says '<--- rotation' should face forward (as if they roll forward)... right? that is, don't mix the sides up.
