Tire Pressure PSi?
Old Jan 7, 2002 | 12:39 PM
JamE55's Avatar
Out Of Control!
Tire Pressure PSi?
What is the normal tire pressure if i'm running 245/40/18F and 275/35/18R?
Thanks!
Old Jan 7, 2002 | 12:58 PM
Vic55's Avatar
Administrator
It depends on the car and the weight you are carrying. If you are talking about your car (E55) then look inside the gas filler door and the correct PSI and load specs will be listed. On the 18's for an E55 I think its around 41 in the front and 48 in the rear with a full load.
Old Jan 7, 2002 | 01:02 PM
JamE55's Avatar
Out Of Control!
Hey Vic!
You're right. Took a look and it's 41front and 48rear. Vic what are you running on your 19's??
Old Jan 7, 2002 | 01:34 PM
Vic55's Avatar
Administrator
Originally posted by JamE55
Hey Vic!
I run 36 psi cold all the way around. Anything more and the middle of the tires will start to wear.
Old Jan 7, 2002 | 05:11 PM
JamE55's Avatar
Out Of Control!
Ok cool!
Thanks Vic!
