19" Lowenhart LD5 on W210...will they fit without spacers?
Front: 19x8.5 ET34 (235/35/19)
Rear: 19x9.5 ET31 (265/30/19)
They came off of a C-class. Now here's the problem. I don't have any spacers or bolts for this set of wheels. Now I have a set of Lorinser LM5's with a 7mm spacer and ET37 stamped on the wheel that fitted without a hitch. My question would be what size and length RAD bolts would I need to run these wheels? I know I need 12mmx1.5 ball-seat, but no clue on shank length. Also, would I need to run spacers? I doubt that I would need spacers, since it's non-AMG, but any help is appreciated, especially from Luke or anyone that has experience with this. Thanks in advance!
One, the wheels fit without spacers, and two, the lug bolts that fit for these Lowenhart LD5 wheels are cone/tapered bolt with the original ET31 and ET34, rear and front, respectively.
My remaining question is, if I am fitting 5mm hub-centric spacers all around, what length bolts should I use if the resulting offsets are ET36 and ET39? I'm looking for Luke or anyone that knows what they're doing before I pull the trigger for the spacers and bolts. Thanks.
