Dymag Wheels ....
Old Feb 7, 2008 | 04:52 PM
otoupalik's Avatar
MBWorld Founder
Dymag Wheels ....
Look what a little English birdie dropped off today for our project CLK Black:
19x10 Front, 17lbs
19x11 Rear, 17.5lbs
*No realize, the weight is all in the middle, so these perform like a much lighter wheel then even that
Anyone interested in the lightest most advanced PERFORMANCE wheel made - just let us know!
thanks
Brad
Old Feb 7, 2008 | 07:20 PM
rays cl55's Avatar
06 E55
bump for some great wheels!
Old Feb 8, 2008 | 11:31 AM
KINGofRIDES's Avatar
07 S550, 06 F430, 07 CGT, 08 Escalade
you think they would be lighter than 17 lbs with a cf lip and magnesium center. thats only saving a few pounds from a forged aluminum wheel, right? whats retail on these dymags?
Old Feb 8, 2008 | 11:48 AM
otoupalik's Avatar
MBWorld Founder
you are missing the savings.
First, show me another 19x10 wheel that is less then 20lbs. Then, you compare the percentage of weight in the hub compared to the barrell.
The savings is that the Dymag's weight is in the hub, not barell. This gives the wheel the functional weight of a 12-13lb wheel. Rotating mass is what you are working to save, and if all the weight is in the center of rotation as opposed to 9.5" away from the center of rotation, that is HUGE.
Also remember, for every one lb you save in unsprung weight, that is equiv to 4lbs of sprung weight.
There are multiple cases of cars seeing 30+ whp gains on a dyno by installing these wheels. Cars from an SLR (tested by MBZ - these will be on the next SLR), Porsche GT3, Evo9, etc.
There is a reason that Mosler, Koenigsegg, Callaway, etc are using these as standard equipment.
These wheels are 2000+ per wheel depending on the size and options.
thanks
Brad
Old Feb 8, 2008 | 09:18 PM
thanks for clearing that up. obviously I have a lack of knowledge in the wheel department.
Old Feb 9, 2008 | 12:57 AM
otoupalik's Avatar
MBWorld Founder
no problem - that is what these forums are for!
Old Feb 14, 2008 | 03:58 PM
KevinS4's Avatar
2004 Audi S4 avant
The Dymags look great.
Check them out on the S7
