Can't find tyre pressure
Old Mar 2, 2008 | 11:55 AM
mun802's Avatar
Hi,
I have 285/35/22 Toyo's fitted to my ML ut can't find what the correct pressure should be. Does anyone know?
Thanks for any help.
Old Mar 2, 2008 | 01:59 PM
carson357's Avatar
2005 C-230 Sport Sedan
you may find the specifications inside the gas door fill area
Old Mar 3, 2008 | 03:01 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
32 front
39 rear
is the default Mercedes pressure recommendation for an ML
Old Mar 3, 2008 | 03:48 PM
mun802's Avatar
Originally Posted by Luke@tirerack
32 front
39 rear
22" aren't standard so I guess the above doesn't apply.
Old Mar 4, 2008 | 09:58 AM
it absolutely does ... tire pressure recommendations are based on the weight of the vehicle not the size of the tires. By plus sizing to 22" wheels and tires you have not changed the weight of the vehicle. The only variation unaccounted for would be if you chose an incorrect size without proper load capacity.
