Do lowering springs require shock upgrade?
thanks
Jim
We're talking for the common 1 to 1.5" drop with the most popular springs (H&R, Eibach, etc.).
thanks
Jim
And people, please don't respond with a "well then just leave you stock shocks on and see for yourself" since I really want to know the facts here and not opinions. I want lowering springs (1 to 1.5") for appearance only,and I don't want to ruin my shocks.
thanks
A lowering spring has less coils vs. ordinary springs and it's also stiffer. Which means it will not bonce as much as normal springs, which means more pressure will be transferred to the shocks. Now that your car is stiffer, your shocks will have to work harder to sustain the pressure, and they're not designed to sustain the extra pressure day in and day out, thats why I said it will wear out sooner. I am sure MB must have done extensive research as to which shocks/springs combination is best for our cars. From what I was told by the MB parts guy, MB stock shocks as well as the AMG shocks are all made by Bilstein. And because they are Bilstein shocks and very well made, they will not die as fast as others. But if you compare a C240 with aftermarket springs vs. one without, the one with aftermarket springs will definitely need to change shocks sooner.
I guess I havent helped much. But hope you do have a clearer picture. Good luck!! :p
I'd hate to think that if I carpooled with a couple of large people in my backseat which caused the car's rear to sit 1" lower, I would ruin my rear shocks in a year
of course as Harris says, it still might speed up wear on the shocks.
I want to do the same thing...lower it 1-11/2" with no harshness...I have 17's and the ride is harsh enuff with those.
I heard Eibach are the way to go - very good ride comfort --
BTW Harris is a "PRO" on the subject....look at some of his other threads !
The stock shocks will not last as long with the sports springs installed. How long the stock shocks will last will depend on your driving style and the roads you drive on.
If you put a lot of mileage on your car or you want to improve your handling even further, then I would suggest that you also upgrade the stock shocks with a set of shocks that matches the springs you will select.
Otherwise, just change the springs and have the car aligned.
PS.
You will also get more tire wear when you lower your car.
Everything has its price!
Eibach says they're springs CAN be used with OEM shocks...I think a few people have done this and are very happy with the ride quality....of course as Harris says, it still might speed up wear on the shocks.....BTW Harris is a "PRO" on the subject....look at some of his other threads !
Allow me to clarify one more time: I dont think our shocks will die within a year or so if you put aftermarket springs on your car. Its just the "Life Expectancy" of your stock shocks will be shortened becuase of this modification. You can certainly put Eibach, H&R or whatever springs on, only expect the OEM shocks will not last as long as it should be. As Franco says, "everything has its price!"
I tell you guys, BIG DIFFERENCE!!!!!
Your shocks should definitely match or those shocks won't last to long. I give them about less then a year, then it's ricer time
Your car will be doing the "Rump shaker" going down the freeway!
), and I'm pretty sure they'd probably work within the acceptable range if you only lower it 1" or so. Now, getting lowering springs, and then cutting them is probably not a good idea.
shocks are meant to dampen the springs, they use frictional forces (oil usually) to dampen the oscillation in a spring when springs compress and extend. in most cases, higher performance shock absorbers offer improved damping over a broader temperature range. this allows the shock absorbers to effectively work when subjected to rapid movements over a long period of time.
think old 80s caddi boats. they have really soft suspensions, what u see is the car undulate up and down kinda slowly...hence "boat." the springs can compress really far before extending. also, since the spring rate is low, it doesn't extend as fast, and so the shocks don't have to work so hard to dampen the effect. heck, even the last generation caddi (before sts and dts) were like that. u could feel the car moving slowly up and down the suspension. take our c36, the springs are significantly stiffer...so when it compresses, it immediately extends back to normal ride height. if the shock doesn't dampen quick enough (with higher rebound rates), then the springs will over extend and start pulling back and compressing again.
i'm babbling here, hopefully, it's a little helpful...
