Hi.. Fitment question..
Old Aug 18, 2008 | 05:44 PM
oneturbo's Avatar
vw 2005 touareg
Hi. I have 2005 sl55.
Some guy has HRE wheel & tire for his Bentley GT
20*8.5 front and 20*10 back. 245/35/20 and back 285/30/20
So you think they gonna fit my sl ?
Old Aug 18, 2008 | 07:01 PM
Hokie1200's Avatar
2004 C230 Kompressor Sport sedan 6 speed manual, 2013 S550 Sport 20" AMG
The wheel and tire sizes you mentioned sound ok, but it gets complicated when offset, caliper clearance, and lugbolt size is thrown in the mix. I went on the Antera wheel website and looked at their application guide. The GT and SL have the same bolt pattern (5x112) and the same lugbolts (14x1.5), but the GT hub bore is smaller. So the HRE wheels made for a GT would have a bore of 57mm and not fit the SL hub that is 66.56mm. You can always get the wheel's serial numbers from the seller and check with HRE. Maybe they could rework the wheel
Old Aug 19, 2008 | 08:27 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
also the SL uses a lower offset
