Camber Corrective Bolts
Subscribe
Nov 27, 2008 | 04:06 AM
I've lowered my w203 c230 coupe about 2" in the front and 2.5" in the rear. The negative camber is causing tire wear. I've read that K-MAC makes an adjustable camber kit, but some people said it was cheap. I don't want to spend that much either.
Does anyone know if camber corrective bolts work or not to adjust 2 degrees of camber? Where could I buy these bolts? Do I need to buy a full camber kit to adjust camber? Thanks.
Will these work? Will they not because W203 doesn't use a MacPherson suspension??
Reply 0
Nov 28, 2008 | 03:10 PM
Camber corrective bolts work...I had the same problem of incorrect tire wear on the fronts then I added the bolts...no problems.
heres the link: http://www.hrsprings.com/products/triplec/
then get your car aligned...
Reply 0
Nov 30, 2008 | 05:55 PM
Does that mean that w203 uses a McPherson strut suspension? And what about crash bolts for the rear?
Reply 0
Subscribe
Currently Active Users (1)
