rare mercedes suspension, need help
Old Dec 7, 2008 | 03:54 PM
E=MC^2's Avatar
W203X2 w201X3 W208 W129
hey all i have a 1986 190e 2.3 16 valve cosworth and my sls self leveling system is sagging im thinking of replacing all the springs and struts with traditional springs probly lowering springs and closing off the hydraulic system for good. can anyone tell me a web site i can order a spring and strut kit for all 4 wheels?? do i have to worry about fitment? would lowering springs for a normal 190e fit on my 16 valve??
everything helps
thanks brian
Old Dec 7, 2008 | 07:37 PM
Untertürkheim's Avatar
the hydraulic system is great, why would you want to cut it off?
You can adjust the hydraulic system easily if it is sagging.
Old Dec 7, 2008 | 10:49 PM
E=MC^2's Avatar
how? its sagging and squeaking
Old Dec 8, 2008 | 07:00 AM
First:
Have you flushed the fluid and checked the screen/filters? If not, I suggest you do that first.
Also, what is squeaking? Our cars are meant to have the chassis/suspension/bushings lubed every 7500 miles, good chance it is not the hydraulic system itself.
Once you have done that, you can adjust the height of the rear suspension by adjusting a bolt attached to the actuator in the back.
