Can I fit the 18x9 AMG wheel on 05 E500 4Matic?
Old Dec 21, 2008 | 08:31 PM
imolas54's Avatar
G550
it's shown as optional rear fitment but i would like to use it in the front also. Would that work?
TIA
Old Dec 27, 2008 | 08:01 AM
imolas54's Avatar
G550
anyone? 18x9 w/ offset of 39? it's shown as rear fitment but would it fit in the front?
Old Dec 27, 2008 | 09:53 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
I have seen some 9" wide wheels on the front of a w211 in the past. They were running a 35mm offset so, 39 wouldn't be that far off. The question is will they clear the brakes ... I will check and post back here ... probably won't be until Monday
Old Dec 28, 2008 | 04:58 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
Hey Luke, sorry to hijack this thread but I have a similar question. I'm looking at a set of 2pc 20x9.5 Brabus VI's and was wondering if this was okay being as they are same size at all four corners going on an 08 E350 4Matic. Am I right in assuming since the size width is the same at all corners I shouldn't have a problem? If this is indeed the case is a 255/35/20 tire size acceptable? Thanks alot for your help.
Old Dec 29, 2008 | 07:46 AM
GABMAN's Avatar
2006 E 500 4matic W211
Hi Luke
I have a similar situation, I have a 2006 E500 4 matic with airmatic suspension. I am about to purchase a set of AMG Sport Wheels, 18 x 9.5 offset ET 38. I need to make sure that these wheels will fit my car and also need to know correct tire size for these wheels.
I am currently running 17" wheels 245x45x17
which I will dedicate for winter with the winter tires I purchased from you guys. Thank You
Old Dec 30, 2008 | 02:21 PM
thhe wheel in question should fit both front and rear of the 2005 E500 4M
