Luke @ tirerack or other experts
Old Feb 21, 2009 | 04:40 AM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
Will a 18tall x 8wide x 35et wheel will fit at the four corners of a C32?
And if so what size tires would be sufficient?(de-staggered/ staggered doesnt matter) I have H&R lowering springs also.
What size spacers if any?
Thanks in advance......................
Driving style: Autobahn
Old Feb 21, 2009 | 07:43 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
On my older W203 I had 17x8 with ET38 running 225s. No problems.
Now, pushing them out 3 mm with a lowering possibly could give you some rub depending on tire and weight carried. Wheel diameter doesn't come into effect because you compensate wit the tire; 17 = 225/45, 18 = 225/40
Old Feb 21, 2009 | 07:53 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
while the specs are appropriate for your C-Class I can not guarantee fitment as the brakes on a C32 are quite large so, caliper clearance may be an issue
